morite
Oct 20, 2014Aspirant
Dead NAS
HI, I have an older ReadyNAS at home and it seems to have died. No power to it. I have tried a different power lead and tried a different power socket. I have also tried a different device with the...
mdgm-ntgr
Oct 20, 2014NETGEAR Employee Retired
We don't sell replacement PSUs.
The NVX (not Pioneer) has a 5 year limited hardware warranty.
The NVX Pioneer has a 3 year limited hardware warranty.
Have you checked to see if your unit is still under warranty?
With e.g. a 314, you should be able to:
1. Put a spare disk (must not be from your array) in the 314
2. Update the firmware to latest
3. Verify the update was successful
4. Power down and remove the spare disk
5. Move your disks across (best to keep drive order the same)
6. Power on
7. Backup your data
8. Do a factory default (wipes all data, settings, everything)
9. Restore data from backup.
Note it would be considerably more difficult with the 104, so I would not recommend the 104.
However if you have a Sparc ReadyNAS e.g. Duo, NV, NV+, 1100 then the 104 would likely not be any more difficult than the 314, however the procedure would be more difficult than using a 314 to get data back from an NVX.
6. Power on
7. Backup your data
