jhkomu
Nov 12, 2019Follower
Default options for NFS share
Hi, what are default options for NFS share (ReadyNAS 4312X)? I have a case where rw,no_root_squash,insecure options are needed. Are those default options for NFS share?
1 Reply
- SandsharkSensei
Settings for my Videos share, for which I have enabled "All hosts" are:
"/data/Videos" *(insecure,insecure_locks,no_subtree_check,crossmnt,anonuid=99,anongid=99,root_squash,rw,async)
The asterisk indicates it is for "all hosts". Cnanging "root_squash" to "no_root_squash" can be accomplished in the advanced settings, as can the anonuid..
If you have SSH enabled, you can see this in /etc/exports, just as with any Linux system. But use the GUI to make changes, or they may get reset on you.
