zero101a
Feb 17, 2019Tutor
Default power condition
Is there a way to change the default power on of the ReadyNAS?
I can turn off my ReadNAS properly (via the webpage or double press the power button).
However if there is a power glitch or...
zero101a
Feb 18, 2019Tutor
Hi Roland, thanks for taking the time to respond.
However my prime concern is that once the NAS has shutdown gracefully, it stays shutdown.
The problem I have is that once power is restored the unit will ignore its previous off state and turn on automatically.
Perhaps this is something I will need to change in the BIOS screen?
Fergus
Retired_Member
Feb 18, 2019zero101a wrote: "The problem I have is that once power is restored the unit will ignore its previous off state and turn on automatically."
Fortunately you are wrong. I can confirm, that the nas stays off, after being shutdown by my ups even after power is available again. That is the beauty of this solution. Nevertheless, there is the drawback (depending on your needs), that you actively have to switch it on, if necessay. WOL works fine in this case.
Kind regards
