Jaroslaw
Mar 18, 2017Guide
Volume: System volume root's usage is 95%. This condition should not occur in normal conditions.
Hello was reading similiar topics and have not found an answer.
RN20400 RAID 5, 4x3TB
Data 4.19TB
Free space 3.98TB
running only antivirus, yet recently started to get:
Volume: System volume root's usage is 95%. This condition should not occur in normal conditions. Contact technical support
You can check if that data is important e.g. using commands such as
# ls -laR /media/USB_FLASH_6
and if not you can delete it using the rm command. If it is important and you don't have another copy of it you should copy it to the data volume before deleting the copy from the root volume.
- jak0lantashMentor
Download the logs from the GUI and post here the section containing "df -h" at the end of the file volume.log
Do you know how to use SSH?
- JaroslawGuide
Nope, sorry never used it and afik it's not enabled on my nas
- JaroslawGuide
jak0lantash wrote:Download the logs from the GUI and post here the section containing "df -h" at the end of the file volume.log
Gosh...I am useless can not find that...:( there is not such log name... I can send you the logs in zip...- Retired_Member
No, please, do not send the logs. Instead, on the admin webpage go to System/Settings and in the services section disable Antivirus by clicking on the concerned button. Make sure, that you keep HTTP, HTTPS and SMB enabled.
- Retired_Member
As a temporary solution/workaround just switch off the Antivirus service and reboot to see, whether its getting back to normal. If it helps, keep it disabled and wait for the fw 6.7 to be released.
- JaroslawGuide
Retired_Member wrote:As a temporary solution/workaround just switch off the Antivirus service and reboot to see, whether its getting back to normal. If it helps, keep it disabled and wait for the fw 6.7 to be released.
OK as a temporary solution I will switch off the antivirus engine and observe. So far I switched off UPNP with Netgear Cloud. , ITunes, SNMP, SSH and Rsync are disabled by default although I was trying to get iTunes running last night, strange.
Thanks
Jarek
