MrRipply
Feb 16, 2018Aspirant
Volume: System volume root's usage is 81%. This condition should not occur under normal conditions.
Hi Community,
Running a ReadyNAS104-01 with firmware 6.9.2. Since a couple of days I have started getting messages from the NAS stating:
Volume: System volume root's usage is 81%. This condition should not occur under normal conditions. Contact technical support.
The usage over my volymes is: 3.09 TB free of 5.43 TB.
Need help to investigate this issue.
BR.
Mr.Ripply
It turned out that the program on the NAS, MySQL was taking up the space.
The system root volume isn't the same as your data volume. It's a 4 GB partition on the disks that holds the operating system and the ReadyNAS application software. If it gets full, the NAS often locks up, and there can also problems with corrupted configuration files (when the NAS tries to re-write them, but that fails because the partition is full). Paid support can fix it remotely, but it is best to deal with the problem before the NAS locks up.
If you are running the AntiVirus service, I recommend disabling it, as it has been misbehaving lately and could be causing your problem.
What apps are installed, and what services are running?
Also, do you have an up-to-date backup?
- MrRipplyAspirant
Thanks StephenB,
We use the below services:
SMB, AFP, NFS, FTP, HTTP, HTTPS, SNMP, SSH
No apps installed.
"An up-to-date backup". Do you mean a backup off the NAS itself?
AntiVirus was not enabled then?
Try logging into the linux shell via ssh, and then check the current root usage.
# cd //
# df -h .
# df -i .
What firmware are you running?
Yes, the data volume of the NAS. If the NAS is used for primary storage, it should be backed up (RAID is not enough to keep the data safe).
Its a different story if the NAS is only used for backup - then it depends on your overall backup plan (how many backups you think you need, etc).
