Jaroslaw
Mar 18, 2017Guide
Volume: System volume root's usage is 95%. This condition should not occur in normal conditions.
Hello was reading similiar topics and have not found an answer. RN20400 RAID 5, 4x3TB Data 4.19TB Free space 3.98TB running only antivirus, yet recently started to get: Volume: System volume roo...
- Mar 19, 2017
You can check if that data is important e.g. using commands such as
# ls -laR /media/USB_FLASH_6
and if not you can delete it using the rm command. If it is important and you don't have another copy of it you should copy it to the data volume before deleting the copy from the root volume.
Jaroslaw
Mar 19, 2017Guide
WOW,
you are GOD to me:
12K /media/._share
2.9G /media/USB_FLASH_6
24K /media
Why is that there? Have not done any backups recently...very strange. Is there any tool to free up that space, please?
And BTW I will not reboot under ssh anymore!
mdgm-ntgr
Mar 19, 2017NETGEAR Employee Retired
- JaroslawMar 19, 2017Guide
thank you very much for dealing with me!
NETGEAR Moderatorthanks for helping hand.Duplicates..how did they get and styed there? Anyways got read of them rebooting to see the effect. - JaroslawMar 19, 2017Guide
All sweet, Log all green!
- mdgm-ntgrMar 19, 2017NETGEAR Employee Retired
Should have clarified I meant to delete the USB_FLASH_6 subdirectory and its contents not the entire /media folder. I assume that was obvious from my post, but what's obvious to me may/may not be to you.
mdgm wrote:Should have clarified I meant to delete the USB_FLASH_6 subdirectory and its contents not the entire /media folder. I assume that was obvious from my post, but what's obvious to me may/may not be to you.
All perfect, understood you corectly, the state now:
20K /media/._share
8.0K /media/USB_FLASH_6
32K /media
Thanks
