Jaroslaw
Mar 18, 2017Guide
Volume: System volume root's usage is 95%. This condition should not occur in normal conditions.
Hello was reading similiar topics and have not found an answer. RN20400 RAID 5, 4x3TB Data 4.19TB Free space 3.98TB running only antivirus, yet recently started to get: Volume: System volume roo...
- Mar 19, 2017
You can check if that data is important e.g. using commands such as
# ls -laR /media/USB_FLASH_6
and if not you can delete it using the rm command. If it is important and you don't have another copy of it you should copy it to the data volume before deleting the copy from the root volume.
Anonymous
Mar 18, 2017As a temporary solution/workaround just switch off the Antivirus service and reboot to see, whether its getting back to normal. If it helps, keep it disabled and wait for the fw 6.7 to be released.
Jaroslaw
Mar 18, 2017Guide
Retired_Member wrote:As a temporary solution/workaround just switch off the Antivirus service and reboot to see, whether its getting back to normal. If it helps, keep it disabled and wait for the fw 6.7 to be released.
OK as a temporary solution I will switch off the antivirus engine and observe. So far I switched off UPNP with Netgear Cloud. , ITunes, SNMP, SSH and Rsync are disabled by default although I was trying to get iTunes running last night, strange.
Thanks
Jarek
