Jaroslaw
Mar 18, 2017Guide
Volume: System volume root's usage is 95%. This condition should not occur in normal conditions.
Hello was reading similiar topics and have not found an answer. RN20400 RAID 5, 4x3TB Data 4.19TB Free space 3.98TB running only antivirus, yet recently started to get: Volume: System volume roo...
- Mar 19, 2017
You can check if that data is important e.g. using commands such as
# ls -laR /media/USB_FLASH_6
and if not you can delete it using the rm command. If it is important and you don't have another copy of it you should copy it to the data volume before deleting the copy from the root volume.
jak0lantash
Mar 18, 2017Mentor
Download the logs from the GUI and post here the section containing "df -h" at the end of the file volume.log
Do you know how to use SSH?
Jaroslaw
Mar 18, 2017Guide
Nope, sorry never used it and afik it's not enabled on my nas
