claynz
May 12, 2024Guide
Defrag and Scrub
Is it necessary to run a scheduled scan on my RN314 for Defrag and Scrub? Volumes are only JBOD and no Snapshots. If so how often should these be scheduled to run?
May 13, 2024Guru - Experienced User
Or this - it spreads the tests around more (not doing all the disk tests in the same months).
Volume 1:
- Disk Test: Occurs at 02:00 on 1 January, 1 May, 1 September
- Scrub: Occurs at 02:00 on 1 February, 1 June, 1 October
- Defrag: Occurs at 02:00 on 1 March, 1 July, 1 November
- Balance: Occurs at 02:00 on 1 April, 1 August, 1 December
Volume 2
- Balance: Occurs at 02:00 on 8 January, 8 May, 8 September
- Disk Test: Occurs at 02:00 on 8 February, 8 June, 8 October
- Scrub: Occurs at 02:00 on 8 March, 8 July, 8 November
- Defrag: Occurs at 02:00 on 8 April, 8 August, 8 December
Volume 3
- Defrag: Occurs at 02:00 on 15 January, 15 May, 15 September
- Balance: Occurs at 02:00 on 15 February, 15 June, 15 October
- Disk Test: Occurs at 02:00 on 15 March, 15 July, 15 November
- Scrub: Occurs at 02:00 on 15 April, 15 August, 15 December
Volume 4
- Scrub: Occurs at 02:00 on 22 January, 22 May, 22 September
- Defrag: Occurs at 02:00 on 22 February, 22 June, 22 October
- Balance: Occurs at 02:00 on 22 March, 22 July, 22 November
- Disk Test: Occurs at 02:00 on 22 April, 22 August, 22 December
claynz
May 14, 2024Guide
Sounds reasonable enough to me, thanks for that!!
