fizzybomb
Apr 18, 2017Aspirant
Deleting Plex off Readynas Rn204
HI Over Easter I tried to access my Readynas and none of the passwords worked, even the recovery password so I had to do a OS reinstall. Once I had done this, Plex then stopped working completly if ...
- Apr 18, 2017
by switching internet browers i have solved this issue thank you for your help
mdgm-ntgr
Apr 18, 2017NETGEAR Employee Retired
Did you run into the ReadyCLOUD Outage?
Do you use home folders for your ReadyCLOUD users? If so any data recovery attempt should be done as the next step.
As for the Plex issue you could try updating to 6.7.1 Beta.
fizzybomb
I dont know what caused it but after doing the OS reinstall I was able to get back into the readynas and all the user were still there i reset the passwords and that is all working fine.
Plex was working fine until I did the OS reinstall but after it would not work and I tried to uninstall plex but it wont unistall it just turns it off then if i try to uninstall it does nothing. Now i can not use if i click on the app and launch it it can not find the page.
