fizzybomb
Apr 18, 2017Aspirant
Deleting Plex off Readynas Rn204
HI Over Easter I tried to access my Readynas and none of the passwords worked, even the recovery password so I had to do a OS reinstall. Once I had done this, Plex then stopped working completly if ...
- Apr 18, 2017
by switching internet browers i have solved this issue thank you for your help
fizzybomb
I dont know what caused it but after doing the OS reinstall I was able to get back into the readynas and all the user were still there i reset the passwords and that is all working fine.
Plex was working fine until I did the OS reinstall but after it would not work and I tried to uninstall plex but it wont unistall it just turns it off then if i try to uninstall it does nothing. Now i can not use if i click on the app and launch it it can not find the page.
mdgm-ntgr
Apr 18, 2017NETGEAR Employee Retired
Updating to ReadyNASOS 6.7.1-T244 (Beta 1) should resolve the issue you're having with Plex.
- fizzybombApr 18, 2017Aspirant
Thank you I Have done that and have deleted Plex put it wont now install it back on
- mdgm-ntgrApr 18, 2017NETGEAR Employee Retired
What errors do you see e.g. in systemd-journal.log for the app removal/re-installation?
Perhaps send in your logs (see the Sending Logs link in my sig).
