emellodew
Mar 28, 2013Aspirant
Demo of OS6
Hi Jabba, Is there a demo or user guide for OS 6. I am looking at buying a 516 but am nervous as there is little info (other than a few you tube videos) on what features are built into the new OS....
Mar 29, 2013Guru - Experienced User
There is a datasheet here which gives the noise level at < 28 dba. It also specifies "extra ram slot" which I'd say implies that the memory is expandable - my guess would be to 8 GB.
It doesn't specify whether the noise is spec'd diskless (or what disks were used). Note the new products support SSD.
