01_Bob
Mar 25, 2021Aspirant
desktop shortcut
Is there a way to create a desktop shortcut for files?
Mar 25, 2021Guru - Experienced User
Do you mean a desktop shortcut to a file (or share) on the ReadyNAS???
Or are you just asking a PC queston?
Ematheu
Please I don't know why i'm receiving this messages that are not for me can you check it thanks
- StephenBMar 26, 2021Guru - Experienced User
I think you ended up subscribed to the thread somehow (and are getting email notifications).
Try clicking on the three vertical dots on the posts to show the options menu. If you see an "unsubscribe" option, then select it.
