01_Bob
Mar 25, 2021Aspirant
desktop shortcut
Is there a way to create a desktop shortcut for files?
01_Bob
Mar 26, 2021Aspirant
A desktop shortcut to the nas file's
Mar 26, 2021Guru - Experienced User
You navigate to the folder (or file) in file explorer, and right-click. You'll see an option to "create shortcut."
Normally it will put that in shortcut in the folder you are in, so you will need to move it to the desktop after you create it. But if you are looking at the share list, Windows will tell you that it can't store the shortcut in that location, and offer to put it on the desktop instead. Obviously you say yes.
