kllngtme
Dec 18, 2011Aspirant
Differences in ReadyNas Pro's?
I've searched but haven't come across anything. Could someone tell me the differences between the ones below? I'm more or less just trying to find out what the most powerful readynas is completely ove...
mdgm-ntgr
Mar 15, 2012NETGEAR Employee Retired
There's a thread on upgrading the CPU: More on CPU specs of the ReadyNAS Pro
Not all CPUs work, so read through that thread and make sure you buy the right one. Please be aware that any attempt to upgrade the CPU will void your warranty which means NO MORE SUPPORT FROM NETGEAR.
If you have SSH access you can monitor the CPU usage using "top". Test out various things you do and see what CPU usage it leads to.
