ChamITGuy
Nov 12, 2018Follower
disable raid
I have a RN102 with (2) 1TB drives in a x-raid radi1 config. What I want to do is:
- install a single 6tb drive
- clone data
- disable raid
can't figure it out. Suggestions?
Retired_Member
Nov 12, 2018Hi ChamITGuy, I would do it like this:
1 - Backup your data
2 - Remove both old 1TB drives from the nas
3 - Prepare the new 6TB drive to not hold any partitions. Could do that with a windows pc. If the disk is already blank, skip step 3.
4 - Insert the blank 6TB drive into the nas. As it is a single drive, there will be no raid.
5 - Restore the data from your backup to the nas
Kind regards
