Osmium
Aug 08, 2022Guide
Disable VPN on Readycloud?
Hi we are running into issues with M1 and M2 mac's that keep getting VPN disconnections. Reinstalling, Uninstalling, Older versions ReadyCloud, Older version of Mac or preview build. Nothing seems t...
Osmium
Sep 08, 2022Guide
They use it when they work from home. On local network at work its working fine.
Sep 08, 2022Guru - Experienced User
If you have a VPN, then ReadyCloud isn't needed at all for remote access. You could simply stop using it altogether.
Migrating is a bit tricky though, since ReadyCloud uses different user accounts from the normal ReadyNAS user accounts. If you are using the home folders feature of the ReadyNAS, you'd need to migrate the ReadyCloud account's home folder's contents to a different one.
Are there other things you are using ReadyCloud for?
