shoemoney's avatar
Apr 17, 2015
Disappointed with lack of knowledge of support #25012209
unboxed my 516, installed 6 5tb wd red drives, booted and like a dumbass installed about every plugin (hey I was excited).
The web interface went down and reboot whatever wouldn't work.
I called support and they told me they only supported 4tb and 6tb red drives and that was my problem.
I was stunned. Really thats why the frontview web interface wouldn't work and he insisted 100% that was my problem....
I asked if I could talk to someone there (politely) who was more knowledgeable. I asked simply if there was a way to factory reset it and he said there was but he wouldn't walk me through it unless I got compliant drives.
2 mins on this forum solved my issue.
Dunno if you want feedback about your support but this was not a good experience. I expected better after dropping a bunch of money.
Thank you forum! Look forward to helping out others as I learn the ins and outs!
  • StephenB wrote:
    BaJohn wrote:
    shoemoney wrote:
    .....thats why the frontview web interface wouldn't work....
    Don't bother with frontview for the RN516, just give the NAS a permanent IP and use that for access...
    Bad advice. You need access to the admin web ui.
    I am looking at the Admin Web Page UI with "Netgear ReadyNAS Admin Page" at the top and tabs of 'System', 'Shares','iSCSI','Accounts' etc.
    That was brought up by using the local name of the NAS box on my PC.
    I must be missing something here, but willing to learn. Please explain where I am going wrong?
  • StephenB's avatar
    BaJohn wrote:
    ...I am looking at the Admin Web Page UI with "Netgear ReadyNAS Admin Page" at the top and tabs of 'System', 'Shares','iSCSI','Accounts' etc.
    Then you are using Frontview. But the OP couldn't access it at all, and you told him it wasn't necessary. I expect you were thinking about ReadyCloud - which isn't necessary.
    Though Frontview is really the OS4 name (the OS5 manual calls it "dashboard" and the OS6 manual calls it "local admin page").
    On the mechanics of launching it from windows explorer - if you click on a storage device "network" pane, then windows will launch the browser - which puts you into the admin page. If you click on a "computer" device it opens up windows explorer, and shows you the share list. If you click on a DLNA device, then windows will launch the media player. My NAS are listed as all three (in the right pane when I click on "network").
    The way people in the forum talk about Frontview, it is as though it is a separate program, similar to Raidiator, maybe local on their front end device, whereas in reality it is the Admin web page, on the back end. Since I started using ReadyNAS with the OS6 I have not been exposed to the term Frontview, and in my mind anything to do with the NAS is 'back'. Perhaps the Netgear team should denigrate the use of the term Frontview, as ambiguous. It is the Admin web page, so why not say so.
    On the question of launching from a windows PC, I just type 'XNAS' in the internet explorer window, as that has been setup in my 'hosts' file. I tend to use 'windows explorer' for most things on the PC, and 'internet explorer' for internet type things not on the PC. Just the way my mind works. Also it enables me to use the term 'XNAS' in my backup routines without having to worry about IP addresses.
    On your point about using 'Network', this is interesting. I always see the NAS in the 'storage' devices, intermittently in the 'media devices' (comes and goes), and I have never seen the shares in the 'computer' device.
  • StephenB's avatar
    Well, that is what they are doing in the OS6 manual - "local admin page". I've been trying to shift to "web admin page" since OS6 but my fingers are very used to typing frontview at this point. Anyway, the OP called it that, so I stuck with it.
    You shouldn't actually need a hosts file anymore, its an obsolete concept that predates DNS. The NAS name should be discovered w/o it on most networks. Though some other devices don't let you set the names - I guess it could be useful for that.
    Devices do tend to come and go on the windows list. Yesterday I saw all NAS in all three categories. Today Computer is missing, but the other two are there. I gave up trying to figure out exactly how windows decides to classify devices a long time ago.
    So I am not the only one. I was leaving this 'quirk' till later, but knowing you can't fix it suggests I shouldn't bother either.
    Perhaps others can comment on this minor irritation. There could be simple answer out there.
ProSupport for Business
