zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
zeke561
Jul 18, 2011Guide
Thanks for the response, the two disks that have no LED status do in fact test as bad. I don't think there is a power supply failure since there is power, 2 of 4 disk LEDs light up, etc. I'm kind of puzzled by the fact the LEDs are not lit, as opposed to blinking. I'm guessing I have to do a reset and start completely over, but I don't want to go thru the reset if there is some other problem or if there is some way to get the device to boot w/ new disks.
