zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
zeke561
Jul 18, 2011Guide
Thanks again for the response, I understand I can't rebuild the data on the disks, and I understand about backups, this device is a backup. I was just thinking it might be possible to somehow boot the os and generate a new raid set w/o destroying my os configuration in the nvram. I also don't want to go thru trying to start completely over if there is some additional problem w/ my hardware, which I sort of suspect since the blank LEDs are not what I expected for simply failed disks.
