zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
TeknoJnky
Jul 18, 2011Hero
zeke56 wrote: I was just thinking it might be possible to somehow boot the os and generate a new raid set w/o destroying my os configuration in the nvram.
the os and config are stored on the disks, so if the array won't boot, then you have lost the config as well.
I also don't want to go thru trying to start completely over if there is some additional problem w/ my hardware, which I sort of suspect since the blank LEDs are not what I expected for simply failed disks.
well you can test hardware if you have a fresh/unused disk, just factory default with the one disk (doesn't take but a few minutes), then you can try booting it in each of the slots.
