zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
TeknoJnky
Jul 18, 2011Hero
the device does not store any config, or run from the firmware.
when the disks are initialized, the firmware installs the os to the drives, so wherever/whatever the drives go, so does the config/os.
if you can not boot, you can not save your config, you will have to setup from scratch.
