zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
PapaBear1
Jul 18, 2011Apprentice
Confirmed. The copy of the OS on the firmware is there to provide a source for the OS when setting up a new array. The copy of the OS that they system operates from is on the drives as is the configuration. It is part of the array. When the array is lost, so is the configuration and the installed OS.
This means you must establish a new array, copying the OS from the flash memory, and establishing a new configuration. Unless you have a configuration that is very complex, it is not all that bad. We have actually spent more time discussing it than it should take to re-do it. The first time you go through it, it can be confusing, but once you have done it, it is easy to just follow the script and make each choice again.
