zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
PapaBear1
Jul 19, 2011Apprentice
Not really. If the drive in your PC died, and you did not have a clone, then when you put the new drive in, you would insert the install disk, install the OS and then go through the set up to customize the BIOS settings. The flash memory with the OS simply replaces the install disk (since there is no CD/DVD drive).
