zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then ...
TeknoJnky
Aug 18, 2011Hero
jsdeprey wrote: installing the OS on a single drive in the array seems strange.
its not stored on a single drive (unless there is only a single drive installed).
I'm not sure of the exact format, but the os partition is at least mirrored to one other drive, if not in a raid0+1 array.
