lennart1
Apr 15, 2013Aspirant
Disc crashed; what to do?
Hi all, One of my disc crashed (a WD 2.0TB / 64mb wd20ears). The disc are in a X-RAID2 config in a RND2000 First, i need to make a backup from the latest files that aren't offsite. So, can i att...
Apr 15, 2013Guru - Experienced User
This is a duo v2 correct? http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If so, the wd20earx is on the HCL, and can be used with your existing wd20ears. A WD20EFRX would also work, and has a longer warranty and no issues with load counts / wdidle3 tweaking.
On backup, you could potentially attach the disk to a desktop PC (powering the NAS down first!).
Though you should also consider network backup.
