lennart1
Apr 15, 2013Aspirant
Disc crashed; what to do?
Hi all, One of my disc crashed (a WD 2.0TB / 64mb wd20ears). The disc are in a X-RAID2 config in a RND2000 First, i need to make a backup from the latest files that aren't offsite. So, can i att...
Apr 15, 2013Guru - Experienced User
If you are running 4.2.22, then you don't have a duo at all. You have an x86 platform (ultra-2, ultra-2 plus, or pro-2).
The model should be listed on the home page of Frontview.
A "hot-add" means inserting the new disk with the NAS running. The advantage of that method is that the NAS detects the new disk insertion, which it cannot do if you insert the drive with the NAS powered down.
