lennart1
Apr 15, 2013Aspirant
Disc crashed; what to do?
Hi all, One of my disc crashed (a WD 2.0TB / 64mb wd20ears). The disc are in a X-RAID2 config in a RND2000 First, i need to make a backup from the latest files that aren't offsite. So, can i att...
Apr 15, 2013Guru - Experienced User
lennart wrote: Ok, tnx.
Now, i'm not quite sure if it's the disc. The logs shows an error that the power is to low. Running with one disc goes fine. With two, one disc hangs.
If you are getting a power out of range error you should check your warranty status and contact netgear support via support.netgear.com. Sort out your product model and purchase date first.
