JovannB
May 18, 2017Tutor
disconnecting/reconnecting a 314 programmatically to/from windows-network - ransomwareprotection
Hi, in times of "wanna cry" and co, I want to use that NAS for intermediate backups in our network (Windows) An example szenario as follows is planned: # switch on (connect) that NAS to m...
- May 19, 2017
Hi,
my solution is now to switch my HP-Procurve-2530er-Ports on/off by SNMPSET.
Thats a quit simple freeware commandline tool which I can control by AHK, perfect.
J.B.
Sandshark
May 18, 2017Sensei
Since most ransomware infects Windows, just disconnecting any mapped drives (NET USE /DELETE) is the most important thing. Using a product like Acronis lets you back up to a NAS without ever mapping a drive where Robocopy is going to need a destination "drive".
WoL can wake the NAS, as can the internal timer. Programatically turning it off is another issue. You could just set the power off time, but that's a gamble that you left enough time for the backup to complete. If the backup is performed by the NAS, though, it will stay on until the job completes.
- JovannBMay 18, 2017Tutor
Hi,
my first thing is, I want to have that "server driven" - that control skript needs to be run on my file-server and NOT on the ReadyNAS.
Inbetween I found and tried another solution as follows partially:
# I've two "honeypot-files" (Excel and Word) on my mapped server shares
# when I start my backup script/procedure (I'll write it with Autohotkey/AHK)
- I check wether these honeypotfiles are manipulated or not (filesize, filename or what else) by ransomware
- if everything is all right, I enable that certain port (where NAS is connected) on my HP-Procurve-Switch via (automated by AHK) CLI-interface-access via SSH-Telnet
- do my backup things (robocopy or what else)
- then I disable that certain switch port of my HP-Procurve-Switch by CLI-Interface-access via SSH-Telnet
so everything should be save enough.
J.B.- JovannBMay 19, 2017Tutor
Hi,
J.B.
