JovannB
May 18, 2017Tutor
disconnecting/reconnecting a 314 programmatically to/from windows-network - ransomwareprotection
Hi, in times of "wanna cry" and co, I want to use that NAS for intermediate backups in our network (Windows) An example szenario as follows is planned: # switch on (connect) that NAS to m...
- May 19, 2017
Hi,
my solution is now to switch my HP-Procurve-2530er-Ports on/off by SNMPSET.
Thats a quit simple freeware commandline tool which I can control by AHK, perfect.
J.B.
Sandshark
May 18, 2017Sensei
Since most ransomware infects Windows, just disconnecting any mapped drives (NET USE /DELETE) is the most important thing. Using a product like Acronis lets you back up to a NAS without ever mapping a drive where Robocopy is going to need a destination "drive".
WoL can wake the NAS, as can the internal timer. Programatically turning it off is another issue. You could just set the power off time, but that's a gamble that you left enough time for the backup to complete. If the backup is performed by the NAS, though, it will stay on until the job completes.
JovannB
May 18, 2017Tutor
Hi,
my first thing is, I want to have that "server driven" - that control skript needs to be run on my file-server and NOT on the ReadyNAS.
Inbetween I found and tried another solution as follows partially:
# I've two "honeypot-files" (Excel and Word) on my mapped server shares
# when I start my backup script/procedure (I'll write it with Autohotkey/AHK)
- I check wether these honeypotfiles are manipulated or not (filesize, filename or what else) by ransomware
- if everything is all right, I enable that certain port (where NAS is connected) on my HP-Procurve-Switch via (automated by AHK) CLI-interface-access via SSH-Telnet
- do my backup things (robocopy or what else)
- then I disable that certain switch port of my HP-Procurve-Switch by CLI-Interface-access via SSH-Telnet
so everything should be save enough.
J.B.
- JovannBMay 19, 2017Tutor
Hi,
J.B.
