PeterDorr
Jan 15, 2012Aspirant
Disk attempted to add is too small with an Identical disk??
I had an HD crash of one of my Seagate ST31500341AS 1397 GB on my ReadyNAS Pro with RAID Level X-RAID2, 6 disks (with dual redundancy) I had already ordered an extra disk when I put the NAS together ...
PapaBear1
Jan 15, 2012Apprentice
All of your settings and the OS (RAIDiator) are on the drives. So when you remove the entire set for your current array, when it sets up the single drive it will be all defaults. Then when you shut down the Pro and restore the original set of drives, all the settings and current version of RAIDiator will be there. Just make sure that the unit is OFF when you do this.
This was the only thing I could think of as it is entirely possible that when a drive is initialized on some other OS, such as NTSF, that even after the partitions are removed, there is some signature occupying a sector. I would be interested in the results.
