chsu83's avatar
chsu83
Luminary
Apr 29, 2019
Disk configuration - using less disks
Hi there,
Is there any chance to configure the volume using less disks? For instance if i currently have 3 disks, 3 TB each so roughly 15TB. Is there any chance to migrate it to a volume with 3x  10 TB disk. Technically it should be possibly but actually I think there's now way which could be used "easily" right? Actually it would be extremely cool if Readynas would support that in a way, where you don't have to reset & setup the NAS / Volume from scratch.
1 Reply
ProSupport for Business
