edecanus
May 22, 2017Aspirant
Disk Refresh Strategy RN314
Hi, I see a lot of threads on disk type/size use but non on refreshing the disks. I have a single degraded disk that I am replacing with one very similar excpept for disk firmware versions to qu...
- May 22, 2017
X-RAID is the current RN314 configuration for 4x 4 TB disks.
jak0lantash
May 22, 2017Mentor
If any disk is showing errors, you should replace it in priority. You should also have an external backup prior to start replacing drives, just in case. Rebuilding a new drive puts strain on all the other drives.
Other than that, replace the drives one by one and wait for the resync to complete between each.
You can also check the official compatibility list: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
If you're in X-RAID mode, the NAS will start expanding your volume when the second drive is upgraded, by creating a secondary RAID array and concatenating both RAID arrays in a single BTRFS volume. After upgrading all four drives, you will have two RAID5 arrays into the single BTRFS volume.
If you're in Flex-RAID mode, the NAS will expand your volume when the fourth drive is upgraded, by extending the unique RAID array and resizing the BTRFS volume onto it.
edecanus
I would do the following steps
Backup NAS data
- replace disk 2 (degraded hdd) with similar 4 TB HDD (pull the live disk and insert the new disk waiting for the sync to complelte)
- 2 weeks replace disk 1 with 6 TB disk ((on compatibility list)
- 2 more weeks replace disk 3 with 6 TB disk
- 2 more weeks replace disk 4 with 6 TB disk
- 2 more weeks replace disk 2 with 6 TB disk
The new disks will be setup automoatically by the RN314 as I understand?
Thanks,
Adrian
- edecanusMay 22, 2017Aspirant
