linusdunkers
Jul 22, 2012Aspirant
Disk Spin Down power management settings
On the page "Just released – RAIDiator 5.3.5 (ARM)" (http://www.readynas.com/?p=6412) from May 24 2012, you will find this in the release notes: The following are changes since RAIDiator 5.3.4: Ne...
gobble1
Jul 24, 2012Aspirant
I have the Readynas Duo v2 with the same Radiator firmware that you have on. I decided to turn the spin down on and so far it seems to be ok for me with my streaming, but I haven't fully tested it to tell you whether or not it's actually spinning down, but I haven't had any lag when playing a file 2 hours after leaving it with the spin down settings on 10 minutes.
FYI I'm using the WD30EZRX drive from WD.
