linusdunkers
Jul 22, 2012Aspirant
Disk Spin Down power management settings
On the page "Just released – RAIDiator 5.3.5 (ARM)" (http://www.readynas.com/?p=6412) from May 24 2012, you will find this in the release notes: The following are changes since RAIDiator 5.3.4: Ne...
Jul 29, 2012Guru - Experienced User
Not sure what implication you are drawing. however it is true that the cost of "relamping" is what is balanced against the cost of energy use. The US government advice says that if you won't be using the fluorescent lights for 15 minutes you should turn them off. (http://www.energysavers.gov/your_home/l ... opic=12280).
PapaBear wrote: Maxblack - even more expensive is the replacement tubes and the union electricians wages to come and change them out periodically. In a large industrial plant setting that drives many more decisions than the cost of anything else.
Anyway, our facilities have corridor lights on timers, and a couple years ago replaced the switches with motion-sensor versions that automatically turn off the lights in the offices if no motion has been detected for a while. So at least in our company there is no debate on turning off the lights.
The corresponding tradeoff for a NAS is balancing the power savings against the disk replacement costs. I haven't seen much definitive on this topic, though there are several researchers who have been looking at variations of Raid that allow some disks to spin down. For instance, concentrating frequently accessed data onto some of the disks can allow the other disks to spin down. One paper on this is here: http://www.eng.auburn.edu/~xqin/pubs/icpp10.pdf It is a bit surprising that there is so little information on what is suitable spin down threshold.
