jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
jedas
There are no installed apps at the moment. Only http, https and ssh services enabled.
By the way, lsof /dev/sda, lsof /dev/sdb, doesn't show any access to files too. I think I could try reseting to factory defaults, to make sure that it's not something i've installed back ago. But I guess there is no way save data on the disks? Even if I disconnect them during reset, they will be wiped out once I connect them to fresh system?
