jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
mdgm-ntgr
Dec 02, 2014NETGEAR Employee Retired
Doing a factory reset with no disks installed achieves nothing as the whole purpose of a factory reset is to wipe the disks installed and do a clean install of the OS.
Backup your data, do a factory default (wipes all data, settings, everything) and restore your data form backup if you wish.
Any clues in the logs zip file around the time the disks are spun up which might explain what is going on?
