jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
algiam
Dec 03, 2014Aspirant
I have a RN104 too.
I had the same problem. I delete and uninstall any apps and still did not work.
Running the top command from ssh I saw instances of mysql (but if I have not installed). I install mysql and then delete now Spindown works well.
When I reboot the NAS, mysql instances be running again !! Spindown now does not work well.
In the end I renamed the "mysql" script in the init.d folder to NAS not run this. Now Spindown works well with everything stopped.
When operating Transmission does not stop any of the 4 HD that I have, is this normal?
Not if it will be the same problem, I hope you can help with anything explained.
regards,
regards,
