jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
dsm1212
Dec 04, 2014Apprentice
Ah, ok, I think what it does then is read from both the mirrors and if it gets an IO error from one side of the mirror it will rewrite the data successfully read from the other side. md supports this automatically, you just need to trigger a read from both sides and it will happen. So bitrot protection will wake up the disks unless the program driving it checks to see if the disks are in standby.
steve
steve
