jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
dsm1212
Dec 05, 2014Apprentice
Ok, I think I see what you are suggesting, but I don't understand what the case you are trying to prevent has to do with bit-rot. If a bit changes on the disk then the sector won't pass internal checksums done by the disk firmware and it will be an IO error. The chance of some bits flipping and the internal checksum still being good are pretty obscure (like not in our lifetimes). Statistically a good read of the wrong data either means someone wrote it or there was a silent failed write that left the old data in tact. Neither of those cases should be labeled "bit-rot". They happen either because someone wrote directly to a leg or the RAID sw/hw itself was buggy or there was a deferred write error.
steve
steve
