jedas
Dec 02, 2014Aspirant
Disk spin-down problem, RN104, fw 6.2.0
Hello, I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down...
algiam
Dec 23, 2014Aspirant
I have a RN104 with firmware 6.2.1, prior to 6.2.0 worked fine the spindown.
I have a problem with Spindown, only 2 of the 4 hd off.
Disc 1 JBOD 500GB
Disc 2 JBOD 2T
Disc 3 1TB Raid 1
Disc 4 1TB Raid 1
Only discs 1 and 3 are stopped, why?
The disc 2 may be some reason, but the disc 4 having Raid with the 3?
I have all the stops aplicacions not have anything, even stopped the SMB, DLNA disk 2 and is the same.
Someone who can help me?
Thank You,
Disc 1 JBOD 500GB
Disc 2 JBOD 2T
Disc 3 1TB Raid 1
Disc 4 1TB Raid 1
Dec 23 05:56:14 Optimus noflushd[12881]: Spinning up disk 1 (/dev/sdd) after 2:58:17.
Dec 23 05:56:15 Optimus noflushd[12881]: Spinning up disk 3 (/dev/sdb) after 3:08:16.
Dec 23 06:07:02 Optimus noflushd[12881]: Spinning down disk 3 (/dev/sdb).
Dec 23 06:07:05 Optimus noflushd[12881]: Spinning down disk 1 (/dev/sdd).
Dec 23 06:25:15 Optimus noflushd[12881]: Spinning up disk 3 (/dev/sdb) after 0:18:10.
Dec 23 06:25:20 Optimus noflushd[12881]: Spinning up disk 1 (/dev/sdd) after 0:18:13.
Dec 23 06:35:22 Optimus noflushd[12881]: Spinning down disk 3 (/dev/sdb).
Dec 23 06:35:24 Optimus noflushd[12881]: Spinning down disk 1 (/dev/sdd).
Dec 23 11:07:53 Optimus noflushd[12881]: Spinning up disk 1 (/dev/sdd) after 4:32:26.
Dec 23 11:08:13 Optimus noflushd[12881]: Spinning up disk 3 (/dev/sdb) after 4:32:49.
Dec 23 11:15:13 Optimus noflushd[12881]: Quitting on signal...
Dec 23 11:17:20 Optimus noflushd[1419]: Enabling spindown for disk 3 [sdb,0:2:ST31000340NS:9QJ3D9PF:300F:7200]
Dec 23 11:17:20 Optimus noflushd[1419]: Enabling spindown for disk 4 [sda,0:3:ST31000340NS:9QJ2ZMYG:300F:7200]
Dec 23 11:17:20 Optimus noflushd[1419]: Enabling spindown for disk 2 [sdc,0:1:WDC_WD20EZRX-00D8PB0:WD-WMC4M0310978:80.00A08:]
Dec 23 11:17:20 Optimus noflushd[1419]: Enabling spindown for disk 1 [sdd,0:0:ST3500418AS:6VMDW5LD:HP34:7200]
Dec 23 11:28:11 Optimus noflushd[1419]: Spinning down disk 3 (/dev/sdb).
Dec 23 11:39:16 Optimus noflushd[1419]: Spinning up disk 3 (/dev/sdb) after 0:11:02.
Dec 23 11:49:17 Optimus noflushd[1419]: Spinning down disk 3 (/dev/sdb).
Dec 23 11:49:35 Optimus noflushd[1419]: Spinning down disk 1 (/dev/sdd).
Dec 23 11:56:44 Optimus noflushd[1419]: Spinning up disk 3 (/dev/sdb) after 0:07:24.
Dec 23 11:56:44 Optimus noflushd[1419]: Spinning up disk 1 (/dev/sdd) after 0:07:07.
Dec 23 12:01:40 Optimus noflushd[1419]: Quitting on signal...
Dec 23 12:01:40 Optimus noflushd[4067]: Enabling spindown for disk 3 [sdb,0:2:ST31000340NS:9QJ3D9PF:300F:7200]
Dec 23 12:01:40 Optimus noflushd[4067]: Enabling spindown for disk 4 [sda,0:3:ST31000340NS:9QJ2ZMYG:300F:7200]
Dec 23 12:01:40 Optimus noflushd[4067]: Enabling spindown for disk 2 [sdc,0:1:WDC_WD20EZRX-00D8PB0:WD-WMC4M0310978:80.00A08:]
Dec 23 12:01:40 Optimus noflushd[4067]: Enabling spindown for disk 1 [sdd,0:0:ST3500418AS:6VMDW5LD:HP34:7200]
Dec 23 12:28:19 Optimus noflushd[4067]: Spinning down disk 3 (/dev/sdb).
Dec 23 12:28:21 Optimus noflushd[4067]: Spindown of disk 3 (/dev/sdb) cancelled.
Dec 23 12:33:22 Optimus noflushd[4067]: Spinning down disk 3 (/dev/sdb).
Dec 23 12:33:25 Optimus noflushd[4067]: Spinning down disk 1 (/dev/sdd).
Dec 23 12:39:08 Optimus noflushd[4067]: Spinning up disk 1 (/dev/sdd) after 0:05:41.
Dec 23 12:39:23 Optimus noflushd[4067]: Spinning up disk 3 (/dev/sdb) after 0:05:58.
Dec 23 12:44:25 Optimus noflushd[4067]: Spinning down disk 3 (/dev/sdb).
Dec 23 12:44:27 Optimus noflushd[4067]: Spinning down disk 1 (/dev/sdd).
Dec 23 13:08:08 Optimus noflushd[4067]: Spinning up disk 1 (/dev/sdd) after 0:23:38.
Dec 23 13:08:34 Optimus noflushd[4067]: Spinning up disk 3 (/dev/sdb) after 0:24:07.
Dec 23 13:13:25 Optimus noflushd[4067]: Spinning down disk 1 (/dev/sdd).
Dec 23 13:13:58 Optimus noflushd[4067]: Spinning down disk 3 (/dev/sdb).
Dec 23 13:31:27 Optimus noflushd[4067]: Spinning up disk 3 (/dev/sdb) after 0:17:27.
Dec 23 13:31:27 Optimus noflushd[4067]: Spinning up disk 1 (/dev/sdd) after 0:17:59.
Dec 23 13:36:40 Optimus noflushd[4067]: Spinning down disk 3 (/dev/sdb).
Dec 23 13:37:32 Optimus noflushd[4067]: Spinning down disk 1 (/dev/sdd).
Dec 23 14:58:32 Optimus noflushd[4067]: Spinning up disk 1 (/dev/sdd) after 1:20:57.
Dec 23 14:58:43 Optimus noflushd[4067]: Spinning up disk 3 (/dev/sdb) after 1:22:01.
Thank You,
