BSMorgan
Sep 13, 2020Aspirant
Disk swap to new ReadyNas?
I have an old ReadyNAS Pro 6 bay. With the recent windows 10 updates, I have lost the ability to connect to the NAS from my PC. If I buy a new 6 bay chasis, can I just move the disks over in order ...
- Sep 13, 2020
Welcome to the Community!
if you are running the default OS of the ReadyNAS Pro 6 you have then you will have to follow a few steps in order to properly migrate the drives into the new ReadyNAS OS6 unit.
https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
If your Pro 6 is working with OS6 then you just need to transfer the drvies to the new NAS.
Alternatively, you can re-enable SMB1 on your updated Windows10 to gain access back to your NAS shares :)
HTH
Marc_V
Sep 13, 2020NETGEAR Employee Retired
HTH
