alisys
Dec 19, 2017Aspirant
Disks compatibility for ReadyNas v2100
Hi,
I have a NAS model ReadyNAS 2100 - (S/N: v22KU326R80001A) and need to chance one of the hard disks.
the problem is that all those that appear in the compatibility list are too old and the stores do not have stock. Is there a current model that is compatible?
Thanks
- Marc_VNETGEAR Employee Retired
Hi alisys
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - Marc_VNETGEAR Employee Retired
Hi alisys!
ReadyNAS 2100 is already EOL and that might be the best reason why the list is not updated for this model.
If you are just replacing a disk with same capacity newer models shouldn't cause any problem. However, using drives that are not listed on HCL is not recommended/supported. The drives may work or may not work too since those are not tested and not marked as compatible so you will be using it at your own risk.
If you are planning to expand your volume there will be limitations on the expansion.
Hope this helps!
Regards
