wchp
Mar 22, 2010Luminary
Disk/Volume Encryption
With the recent introduction of MA CMR-17 law, most businesses are now required/encouraged to encrypt all customer data. What if any timeline is there for the Readynas products to support AES encrypt...
mdgm-ntgr
Oct 19, 2010NETGEAR Employee Retired
chirpa has a thread where he has tested encryption using EncFS. See http://www.readynas.com/forum/viewtopic.php?f=35&t=29874 which demonstrates that he has had a look into it.
Doing this is unsupported, but if you have the technical knowledge to do it, you can go ahead and set it up.
