simonzee81
Aug 05, 2022Guide
DNS error message 6001010060 readycloud login and admin page
Hi, since last week i'm getting an error message when using readycloud. As soon as i login i'm getting the below message: when i click OK i can access the nas just fine and nothing el...
- Aug 09, 2022
Hi!
It should be fixed now.
Please let us know if you're still encountering the issue.
JeraldM
NETGEAR Community Team
scrjs
Aug 07, 2022Apprentice
I am seeing the same error when I click on "Check for Updates" as noted below
This was working fine recently (in the last week)
I can also confirm that communications is not an issue as this ReadyNAS has sent me email alerts (tested in the last five minutes) and I am receiving Antivirus updates.
dingjs1421 or B_L can you confirm if this problem is at the Netgear end or any other thoughts?
StephenB - Are you seeing this issue?
- StephenBAug 07, 2022Guru - Experienced User
Yes. I'm thinking it's an issue with the DNS record for Netgear's update server. Whatever it is, it's a Netgear backend problem, not something wrong with my ReadyNAS.
- scrjsAug 07, 2022Apprentice
Thanks StephenB for the response Sir!
StephenB wrote:
scrjs wrote:I am seeing the same error when I click on "Check for Updates" as noted below
I agree with you. Comforting to know others around the world also see this issue.
Hope the team netgear take a look and fix this inhouse soon as it appears to impact their a significant proportion of their community of users.
- fkhalilAug 08, 2022Initiate
I am having the same exact issue. Hope it gets resolved soon.
- B_LAug 08, 2022NETGEAR Expert
We are working on this issue and will fix it asap.
- scrjsAug 08, 2022Apprentice
Hi B_L ,
B_L wrote:We are working on this issue and will fix it asap.
Thanks for the info Sir and great to hear from you 👍😀
- AlmudenaAug 09, 2022Aspirant
As Negtear surreptitiously discontinued the ReadyNas line of products, with no prior warning and even no official announcement, my understanding is that they might cease to provide OS updates or security update altogether and disconnect the corresponding server. .
I am not the only one to fear that we will soon have no further OS or even security update: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Future-ReadyNAS-OS6-security-updates/td-p/2245485.
I look forward to an Netgear employee confirming that Netgear will keep updating the OS or at least providing us with security updates.
