Bruci's avatar
Bruci
ReadyCLOUD Androd app Vers 2.0.0 - message bubble?
ReadyNAS 102 DEVICE with Firmware 6.9.4.
Question: Samsung Android ReadyCLOUD app is showing an 'orange bubble' with 248 written inside. What does this mean and how can I remove this bubble? My assumption is that it represents some number of attempts to access my ReadyNAS device, or a quantity of messages. I can access the NAS 102  via ReadyCLOUD on the Android and my PC.
Thanks
  • Bruci's avatar
    Bruci
    Nov 09, 2018
    Stephen,  Thanks for assistance, I will let the matter rest there and will look into OPEN VAN and Zero tier as possible solutions. I noted on the ReadyCLOUD app Playstore download on my tablet that others have said the later version of this app was causing problems. As long as I can access my NAS device via a browser this gives some comfort. Again thanks.
    • Bruci's avatar
      Bruci
      Stephen B,
      I do not see the alert when opening the app or when I swipe down on phone. I used the link you supplied and de-activated the notification under app settings but the alert bubble did not go away even after restart of device. Image supplied to show my fault
      • StephenB's avatar
        Is the app working properly (giving you access to the NAS files)?
ProSupport for Business
