Bruci
Nov 06, 2018Aspirant
ReadyCLOUD Androd app Vers 2.0.0 - message bubble?
ReadyNAS 102 DEVICE with Firmware 6.9.4.
Question: Samsung Android ReadyCLOUD app is showing an 'orange bubble' with 248 written inside. What does this mean and how can I remove this bubble? My ass...
- Nov 09, 2018
Stephen, Thanks for assistance, I will let the matter rest there and will look into OPEN VAN and Zero tier as possible solutions. I noted on the ReadyCLOUD app Playstore download on my tablet that others have said the later version of this app was causing problems. As long as I can access my NAS device via a browser this gives some comfort. Again thanks.
Nov 06, 2018Guru - Experienced User
It certainly is a alert count of some sort. Do you see any alerts when you open the app (or when you swipe down on the phone)?
If you just want the counter to go away, you can use the procedure here: https://www.addictivetips.com/android/how-to-enable-or-disable-notification-badges-for-apps-on-android/
- BruciNov 06, 2018Aspirant
Stephen B,
I do not see the alert when opening the app or when I swipe down on phone. I used the link you supplied and de-activated the notification under app settings but the alert bubble did not go away even after restart of device. Image supplied to show my fault
- StephenBNov 07, 2018Guru - Experienced User
Is the app working properly (giving you access to the NAS files)?
- BruciNov 07, 2018Aspirant
From Android device answer is no. When app is opened first screen identifies my NAS device but when attempting to link it the response is 'you have no shares on this device'.
On my pc however I can not only access my NAS device but also the folders/documents etc. The Network screen shows all the main folders and the word 'share' written underneath.
I have uninstalled/reinstalled the app on Android device without curing problem. Clearly an Android link issue
