simonzee81
Aug 05, 2022Guide
DNS error message 6001010060 readycloud login and admin page
Hi, since last week i'm getting an error message when using readycloud. As soon as i login i'm getting the below message: when i click OK i can access the nas just fine and nothing el...
- Aug 09, 2022
Hi!
It should be fixed now.
Please let us know if you're still encountering the issue.
JeraldM
NETGEAR Community Team
Aug 07, 2022Guru - Experienced User
scrjs wrote:
I am seeing the same error when I click on "Check for Updates" as noted below
StephenB - Are you seeing this issue?
Yes. I'm thinking it's an issue with the DNS record for Netgear's update server. Whatever it is, it's a Netgear backend problem, not something wrong with my ReadyNAS.
scrjs
Aug 07, 2022Apprentice
Thanks StephenB for the response Sir!
StephenB wrote:
scrjs wrote:I am seeing the same error when I click on "Check for Updates" as noted below
I agree with you. Comforting to know others around the world also see this issue.
Hope the team netgear take a look and fix this inhouse soon as it appears to impact their a significant proportion of their community of users.
- fkhalilAug 08, 2022Initiate
I am having the same exact issue. Hope it gets resolved soon.
