tasone
Aug 13, 2021Aspirant
Does not Boot
Hello, I have two Netgear ReadyNAS 2100, and I tried to do a firmware update to the device, but after it was done and rebooted, nothing happened I unpluged and waited a bit and tried again to...
Sandshark
Aug 13, 2021Sensei
What did you try to update to? I hoipe it wasn't OS6. The 2100 (V1) can't be updated to OS6. If you did try going to OS6, you may well have bricked the NAS. But you could try a USB recovery to the proper OS.
tasone
Aug 14, 2021Aspirant
Hi,
Yes i was trying to get to os 6
I was using the following lsite guide to do it
https://blah.cloud/just-for-fun/upgrading-a-legacy-readynas-from-raidiator-4-2-x-to-6-2-x/
I think it is bricked as well
Andrew
- StephenBAug 14, 2021Guru - Experienced User
Try the USB recovery, it might get you back.
OS-6 requires a 64 bit x86 processor, and unfortunately several legacy 4.2.x NAS only had 32 bit processors. They can't be converted.
- tasoneAug 18, 2021Aspirant
I already tried a USB reinstall, still nothing
- SandsharkAug 18, 2021Sensei
Keep trying. See this thread from a user who recently did the same thing and recovered: ReadyNAS-2100-bricked
Thanks, i will try again and see were i get
