PhotoRecon
Feb 20, 2012Follower
Does NV+ work with Windows 7 64 bit?
Hi. I have the NV+ (not the NV+ Version 2). Before I purchase hard drives for it, will it work with my Windows 7 OS? Thanks.
mdgm-ntgr
Feb 20, 2012NETGEAR Employee Retired
Whilst it should work fine with your Windows OS on the latest firmware, if you've only just purchased it I'd be inclined to return it and buy a newer model. A newer model supports 3TB drives, includes a much newer version of samba (Linux project used for Windows file sharing) and is a much more future proof option.
Welcome to the forum!
